Wobbly wheel
Old 03-01-2007, 08:48 PM
pastfast125
pastfast125's Avatar
Default Wobbly wheel
My steering wheel is really wobbly. No matter what position it's in you can wiggle it all around like more than 1/2" to each side. Is that normal or do I need to tighten somethin up?
pastfast125 is offline
Old 03-01-2007, 08:59 PM
89 fox
89 fox's Avatar
Default RE: Wobbly wheel
https://mustangforums.com/m_2801264/tm.htm
does anyone even try to read before they post?
89 fox is offline
Old 03-01-2007, 09:03 PM
pastfast125
different problem. Mine isn't a loseness when you are turning the wheel, it's like the nut that holds the wheel on is loose, so I can ush on the right side of the wheek, and it'll move forward and left side will come back. get what I mean?
Old 03-01-2007, 09:07 PM
89 fox
89 fox's Avatar
oooooo...my bad....so the actual wheel itself is loose....try pulling the horn off and see if you can tighten the nut up....it should come right off unless you have airbags
89 fox is offline
Old 03-01-2007, 09:08 PM
pastfast125
ok I'll check that out, I wasn't sure if that was just normal or not.
Old 03-01-2007, 09:11 PM
89 fox
89 fox's Avatar
it happens with pulling on the wheel, vibrations, etc....should be a simple fix
89 fox is offline
Old 03-01-2007, 09:33 PM
silver91gt
silver91gt's Avatar
and if it has airbags, they're only held in by 4 screws
silver91gt is offline
Old 03-01-2007, 10:09 PM
85gtintheworks
85gtintheworks's Avatar
uhh mabey it could be your tie rods being very bad that might be a possibility nevermind i just read that other thing
85gtintheworks is offline
Old 03-01-2007, 10:13 PM
89 fox
89 fox's Avatar
the steering where is loose front to back....not when turning
89 fox is offline
Old 03-02-2007, 12:49 AM
LCBlackDep183
LCBlackDep183's Avatar
ORIGINAL: 87black snake
Thats what she said
LCBlackDep183 is offline
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Wobbly wheel
