removed smog EGR?
removed smog EGR?
Yesterday i removed my smog pump and waht not. the belt u need ispart number:850k6. if anyone is wonderin.
thx to the website i found out the way 2 route the belt in a matter of min thru a quick search.
ok, now i wanna remove my egr.i got rid of the vacuum lines and stuff, now how do i remove the egr valve. what do i use to pplug the whole or can i just take the spacer off completely.
RE: removed smog EGR?
I just recently removed mine. Most people either fabricate or buy a metal plate that blocks the hole. Of course, it's a little different on an SN95 than the fox. I got a cheap metal cap to cap off the header where the EGR tube was attached.
To keep the CEL from getting tripped, I just used my tweecer to tell the computer that there was no smog or EGR on the car. That took care of that problem. Buyt most people that don't "tune" it out will either buy or make their own resistor to plug in and fool the computer into thinknig it is there and working normally.
ORIGINAL: 93stallion302
can i just take off the EGR Spacer and cap the header tubes then, or do i need the spacer there for sum other reason?
Samseed where the hell Did you find the cap for theheader. I cant find one anywhere so I cut my tube in half that connects from my header to valve and I crimped it shut. That is temporary. I as well blocked off my egr valve with a cut out piece of a license plate.
jwog666
12-27-2021 08:09 PM
