those of you with superchargers
#51
RE: centrifugial supercharger
ORIGINAL: dimebag
so the vortech pully is 8 rib i assume? how would u run it if it were 6 and the novi s/c is an 8?
how safe is 11/12 psi on a stock motor, and what can i expect power wise from it? and from 6ish psi?
It doesn't work with the Vortech SC trim. It is a "trick" for the Novi 1000 guys. It was not designed for it.
A stock motor will hold 11-12psi.Wait a little while and I'll post some numbers with my stock motor. I plan on adding an E cam (free) and a Performer RPM intake (sitting on the shelf). I'm only using stuff that I have. The entire swap is only costing me gaskets.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
