Flywheel question!
Flywheel question!
okay so i took apart my clutch today and we totally didnt think ahead very far and anyways we found out we needed a flywheel. my question is does it matter how many teeth there are on the replacement i get?
RE: Flywheel question!
Hard to replace a clutch in a Mustang. You are kidding right? Its one of the easiest things I have done to my car. If you have any mechanical ability you will be fine. Just make sure you reset the quadrant if its not an adjustable setup.
ORIGINAL: 85stang1373
you can take yours somewhere to have it resurfaced, pretty much any machine shop does them i think as long as there are no stress cracks and it is not horribly pitted. I was told you need one with the same number of teeth.
The other thing to remember is that stock motors will use a 50oz imbalance
stroker motor kits are normally balanced for a 28oz imbalance
some high reving motors will be specially balanced for a 0ozimbalance
The last thing to think about is you may want to get a billet steel cut flywheel. They are a bit more $$ but they are SFI aproved, which is required by NHRA drag strips if you run lower E.T.s
ORIGINAL: mcfomco
ORIGINAL: mcfomco
I have long tubes as well. I still think it is an easy job.
