MASS AIR QUESTION
MASS AIR QUESTION
hello evr1 i just bought a bigger mass air off of ebay..It's 70 mm mass air like the 93 cobras had but its calibrated for 19 lb injectors b/c that's what i have, well i insatlled it and now my car idles like ****..it already runs a lil rich so could that affect the idle now?...it idled great before, and i have the timing bumped to 12*
heres the link it might work:
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
RE: MASS AIR QUESTION
HERE IS THE DEAL. IF YOUR INJECTORS MATCH THE CALIBRATION THEN THE CAR JUST NEEDS TO RELEARN, THE MASS AIR DOES THIS ON ITS OWN IT CAN TAKE UP TO 4 DAYS. IF YOU WANT TO HELP OUT THE PROCESS DO A LOT OF DRIVING DO SOME STOP AND GO TRAFFIC SOME 0-60 AND SOME HIGHWAY CRUISING. THEN THE PROBLEMS SHOULD BE NO MORE.
im positive i have 19 lb injectors...the car is more stock than anything...does it really take time for the comp. to re-adjust itself?, or maybe u think it wasnt calibrated right..once againg look at the pic
looking at the mass air meter wont tell us whta the calibrations is. u said ur car was running a lil bit rich? well the comp. is programmed to run off the mass air and the injectors beeing somewhere inbetween 39 to 43 psi. if ur at more then 43 psi then the injectors will technicly be bigger then the #19. so it wood be like ur car has #22 injectors with a maf thats calibrated #19. make sure ur psi is rite
allow it to relearn. if for some reason you still cant get the idle to settle then try this
Idle speed set on the throttle plate is too high; usually this error is characterized by a very erratic idle and stalling when coming to a stop.
Set the throttle by removing the connector from the idle speed control motor.
With engine warm and air conditioner turned off, set idle speed at 700 RPM using the throttle screw.
Reconnect idle speed motor and check for engine stability.
Check system for vacuum leaks and fix them.
this worked for me
this worked for me
