will 350 HP b possible?
ok i hav a 95 Gt with the parts mentioned in my sig. i want to get 350 Hp. it will be a 302 with all forged internals, a B cam, GT40 Thumper ported heads and intake, 1.7 rockers, 24lb inj., 70mm t/b, and 76mm MAF with 75 to 100 shot of juice. will 350 HP b possible on the spray? What do u think my HP will be N/A.
RE: will 350 HP b possible?
Yea, you should be higher than that with the spray. I'd look into a different cam tho....You can prolly get better power out of a different cam. You should be right around 300rwhp ( roughly ) NA
at least he did good by getting the 1.7 rockers. he has the lift of the E cam but alot more duration from the b cam which is good for making more power. there are better cams out there but like i said at least they done well picking out the 1.7's to compliament the b cam. i think he will be around the same range as someone with a tf kit
yea the only reason i was gunna get that cam was b/c for 900 thumper was gunna port the heads and lower intake and throw in either a B cam or TFS 1 cam.....what cam do u think wud suit me better?
no my motor isnt assembled yet. i hafta send the heads and intake away for porting...thats why im asking for suggestions before i finsh.....i didnt even buy the internals for the botom end yet. any suggestions would b aprreciated.
r u planning on keeping it n/a or using a supercharger down the road? if u plan on using the spray still i would bump the compression up. ask the thumper guy what the compression would be with flat top pistons. if its lower than 10.5 ask him to mill them down enough to make the compression @ 10.5. Are you having bigger valves put in? i think a 2.02 intake will work in the GT40 head. If not i know a 1.94 will then use a 1.6 exhaust valve to go along with it.
