replacing motor mounts
i put a trick flow intake with 1 inch spacer, now when i punch it, the engine intake hits my hood, now i got a dent in it.... my mounts look pretty worn out and was going to get new ones... how long does this take to replace both mounts if you have all the tools you need and a lift? also, is there any aftermarket motor mounts that could make my engine sit lower? thanks alot
RE: replacing motor mounts
torque strap is like a rachet strap. hook it to your motor and to the driver side K member or body rail.[something solid and permant] when the motor torques it wont let the motor move and with this set up youll actually plant more power cause. less moving mass they used torque straps on turbo buicks, they also use straps or even brackets on all kinds of high hp cars
if i went cowl hood, i wouldnt go vert mounts.... reason im not going cowl yet is because i cant find anywhere to buy it for a good price loccaly, and i cant find it any cheaper than 500 plus shipping online, anyone know where i can purchase one online for under 500 dollars including shipping?? thanks alot.......... also those tourqe straps sound like a good temp fix, i think i'll give that ago right now.. seein as how i got some rachet straps in the garage...
all you need to make a homemade torque strap is a heavy turnbuckle available from any hardware store along with some bolts and washers to mount it between the shock tower and the front side of the block or head to hole the engine from rotating. might cost $10!
I have a related question. Wouldnt running solid motor mounts vibrate the hell outta everything in your car? Seems like they would be a big no no for a daily driver to me.
ORIGINAL: 94Cbra
