HELP ME REAL QUICK!!
You set timing with the notch on the balancer that says 0 btdc right? Also do you guys do it at idle or what? Thanks a bunch I'm leaving in like ten minutes to work and wanted to know before I left
RE: HELP ME REAL QUICK!!
i did mine at idle, and used the notch. Make sure you disconnect the brown plug, I dont remeber what its called but if ou dont do it you timming will go back to stock after your done
lincolnshibuya
12-08-2015 04:37 PM
autoedit
09-27-2015 06:37 PM
09-25-2015 06:30 PM
