Need a stock MAF before friday night!
can anyone help me? does anyone have one layin around?
i also need the stock tubing.. if i cant get the tubing.. i can use my old stuff, and rig it together with a cone filter until i can get something different..
hoping someone can come through for me!
pretty simple inexpensive thing, that my car will not run without!
im pretty excited about the new motor, and maf conversion
were stabbin it in friday
RE: Need a stock MAF before friday night!
Which computer?
We need the catch code - A9L, A9P, X3Z, etc...
This will make a difference, as we may be able to expand your search a little, to include some better MAF units.
ORIGINAL: cbennett
yeah 19lb injectors..
i will pay for shipping!
This is a 70mm tube, which is a direct swap for an A9* computer, as long as the 19's are still in use.
Here is a list of some of the Factory uses for this meter...
94-95 Mustang 5.0
94-95 Mustang 3.8
94-95 Mustang Cobra 5.0
92-94 Crown Vic 4.6
but there may be others.
the important features are...
70mm tube diameter
part number 'F2VF' on the MAS (the little black sensor box)
This meter would be a mild performance upgrade, worth a couple (5-7)HP.
The only 'converting' required is an inlet tube adapter. I can't find a good link right now, but they are available.
If nothing else, some guys have simply cut the flange off the 70mm housing and slipped their inlet hose over the MAF (similar to the original setup).
If you can't find one of these meters...
The factory meter for the MAF Mustang 5.0 was a 55mm tube with a 'F1ZF' MAS.
This sensor was also available on...
88-93 Mustang 5.0
89-95 Taurus SHO 3.0
88-93 T-Bird 3.8
92-93 T-Bird 5.0
Hitting the j/y should yield a good meter...
jason
