Help with 5 Lug Conversion on 89 hatch - Page 5 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 03-16-2007, 07:24 PM
  #41
kcsoa22
Default RE: Help with 5 Lug Conversion on 89 hatch
Cool, I am good to go. Picked up both spindles today. I noticed some people said that they noticed a spongy pedal with this conversion. PJB-Did you have to do anything with your master cylinder or brake booster for this swap?
kcsoa22 is offline
Old 03-16-2007, 09:31 PM
  #42
ddeaton66
Great....add a few more dollars to the project, how bout if you get a k-member & coil overs? OR get the struts from the 94 when I get the spindles??
ddeaton66 is offline
Old 03-16-2007, 10:17 PM
  #43
kcsoa22
Now thats got me thinking, will my 89 struts bolt up to the 94 spindles? And If I buy new struts, which I plan to do I buy them for an 89 or 94?
kcsoa22 is offline
Old 03-16-2007, 11:36 PM
  #44
PJB
ORIGINAL: kcsoa22
I havent actually done the swap yet due to the weather but I dont plan on touching the master cylinder.
For a rear drum setup its not required to do anything to it.
PJB is offline
Old 03-16-2007, 11:37 PM
  #45
PJB
ORIGINAL: kcsoa22
Theyll bolt up.
I believe '87- atleast '95 struts are the same.
PJB is offline
Old 03-17-2007, 02:16 AM
  #46
kcsoa22
ORIGINAL: PJB
ORIGINAL: kcsoa22
Theyll bolt up.
Why would summit have 2 different part numbers for the strange struts then? One part number if I enter 1989 mustang and a different one if I choose 94 mustang. Is the dampening different, or the mounting? I sent summit an email asking the same question. Hopefully I will get a response soon. I thought they were the same also, until I checked part numbers.
kcsoa22 is offline
Old 03-17-2007, 02:21 AM
  #47
ddeaton66
How bout if you get a k-member & coil overs? OR get the struts from the 94 when I get the spindles?? Will they bolt up to the '86?
TIA
Old 03-24-2007, 03:24 AM
  #48
93cobraR306
i wanted to know if the 94-95 front spindles will bolt on my 84 lx 5.0? or would i need to upgrade my front suspension to 87-93 first?someone please help!!!
93cobraR306 is offline
Old 03-24-2007, 11:40 AM
  #49
ddeaton66
I am not sure, but if I have understood what has been said so far, yes you would have to upgrade to 87-93 struts at the same time you upgraded to 94-95 spindles. My question is will the 94-95 struts work on the 84-86? If your getting the spindles it should be cheap enough to grab the struts too.
HRnB
GT350 S550 Tech
12-18-2015 10:35 AM
11-10-2015 12:39 PM
10-07-2015 08:02 PM
DCole24
09-11-2015 11:50 AM
Quick Reply: Help with 5 Lug Conversion on 89 hatch
Featured Sponsors
