which is a better fit?
hey guys whats a better choice a 65mm t/b or a 70 mm. the rest of the set up is, gt40 intake, gt40 cast iron heads, 76mm maf, e303 cam. would the 70mm be too much or are those enough mods for it? ps im still going to run the stock 19 lb injectors
RE: which is a better fit?
Ive got a 70mm on mine and for right now its just got an intake with stock heads and a cam (new heads are on their way) and it runs fine.
With your mods a 70mm will be fine.
If you're getting aftermarket heads, the 70 may be a better choice, depending on what other future mods you'll have.... If you'll have the GT40's for a while, 65 would be the better choice (assuming they're stock, not ported).
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
