what do i need to do?
Old 11-04-2004, 05:32 AM
HAUS
HAUS's Avatar
Default what do i need to do?
what do i need to do to take out my old fuel pump and installl my new one. i have a 1992 lx 5.0. thanks
HAUS is offline
Old 11-04-2004, 12:46 PM
roundman
roundman's Avatar
Default RE: what do i need to do?
you have to remove the fuel tank to get to the pump to replace it. it's not all that hard to do if you run the tank about empty or siphon the gas out of it first to remove most of the weight. support the tank with a floor jack and loosen the straps which hold it up, then disconnect the clamp holding the fill tube into the tank and completely loosen the hold down straps. slowly lower the tank some in order to get to the electrical connections and disconnect these and the fuel lines, then you can lower the tank all the way down. you will need the special plastic tool in order to disconnect the high pressure fuel lines, it's available from any auto parts store for about $15 or less. it comes with two different sizes for the two sizes of fuel lines on a Stang. once you've the tank down and out from under the car, use a brass or other non-sparking metal rod to knock loose the clamping ring holding the tank and level gauge in place and unscrew it all the way. then lift out the fuel pump and level gauge. replace the pump and sock with a new one and reverse the steps to put it all back together.
roundman is offline
Old 11-06-2004, 03:31 AM
HAUS
HAUS's Avatar
thanks roundman. i apreciate all your help you given me
HAUS is offline
Old 11-06-2004, 10:55 AM
87mustang347
87mustang347's Avatar
jeeze i wish it was that easy for me, roundman pretty much set it all. juss be prepared for the unexpected. i had a hard time putting the new fuel pump in cause it doesnt juss drop in u gotta monuver it in a weird way, my suggestion is, when u go to put the new pump in look threw the filler neck whole on the side of the tank so u can see where the pump is goin. it was al ot easier that way for me.
87mustang347 is offline
Old 11-06-2004, 10:59 AM
87mustang347
o yah one more thing. get a couple of buddies of urs to help u put the tank back up. its easier bringin it down then up but i had to drop my tank one more then one ocasion and it was nearly impossible 2 man job. what i did was this. one guy on each side of the tank holding it in place and one guy jacking up the tank. if u can do it another way, LET ME NO
Old 11-07-2004, 10:32 AM
vfast
I ♥ Acer
vfast's Avatar
and please buy a bigger pump a min of a 110 lph pump
vfast is offline
Old 11-07-2004, 01:42 PM
HAUS
HAUS's Avatar
ORIGINAL: vfast
yeah im going to get 110 lph. the stock one at pep boys is like 130.00 for it so i decided to get the 110 lph for like 80.00 and v i guess running out of gas a bunch of times finally cought up with me. im just glad its not my daily driver. just a project car.
HAUS is offline
Old 11-08-2004, 04:33 AM
HAUS
HAUS's Avatar
i plan on modding in the future so would a 155 lph be worthwhile or is that too much right now on a stock application or should i just stick with the 110 lph for now.
HAUS is offline
