Pics of Blow off valve install
Does anyone have pictures of either a blow off valve or diverter valve installed on their 5.0? I want a BOV however i heard that with mass air you need to recirculate the air back into the intake tube rather than with a BOV that vents into the atmosphere. Any help is appreciated. thanks
RE: Pics of Blow off valve install
i assume you're running a blower. you don't have to reroute it back into the intake if you have it mounted before the maf. that is if you're running a blow thru setup. if not then you need to have the discharge go through theintake after the mafagain after it blows off. the air is already metered and if you release it to the atmos. it will make your a/f go pig rich.
ORIGINAL: moe356
whats wrong with having a blow off valve?
