How is the F-303 cam for my car?
#22
RE: How is the F-303 cam for my car?
but isnt so much emissions friendly and lacks lift but does have duration and not so friendly idle as the E
ORIGINAL: 4fit?
In my opinion, the B cam sounds far better than the E cam. It gives a great thump to the idle, especially if you are running an offroad pipe.
#24
ORIGINAL: 89LXcoupe
Does anybody else agree with ohsoquik02?
#26
ORIGINAL: 94Cbra
Not to highjack or anything but, how do you figure different lifts with different rockers? I have 1.7 rockers on my car and most of the cams I look at are tagged for 1.6 rockers. So if lift is .480 w/1.6 Rockers, how would I figure out what is is with 1.7 rockers? Also, anyone know max lift for standard GT-40 heads?
#27
but the dude asked if he could run it with his current set up and NO he cant with 1.72s
ORIGINAL: mustang30240
f-cam works on stock heads and pistons ive seen it done
#28
what cam has a rougher idle? e? or b? are they both smog legal? would one have a better chance of passing smog than another? i live in nor cal if its a difference in smog , also wich would provide more power?
#29
B cam has 224 duration 480 lift E cam is 220 duration 498 lift. e cam is better idle and better for emissions. B cam gives you just a tad bit more power but not as much lift. these two cams are very close in performance. a b cam car needs a nice stall when backed to a auto. E cam car doesnt need a stall but it wouldnt hurt
ORIGINAL: nemethjames1
#30
stay away from those abc. cams dude,your stock springs will coil bind with anything over .500 lift and if you go with an e cam you will tag your valves,just so slightly...trust me on this cause it happened to me.
