do i need a tune ?
RE: do i need a tune ?
Dont go too radical on the cam or youll loose out on bottom end power. TF st. 1 or F cam would be fine for your setup. Port match the intake and dont worry bout the tune right now. Your A9L should be fine with just a mild setup. But it always helps to tune. Get an adjustable FP reg. The cam in the link above should work fine also.
CCA-35-440-8
COMP Cams Magnum Hydraulic Roller Camshafts
Camshaft, Hydraulic Roller Tappet, Advertised Duration 281/ 281, Lift .512/ .512, Ford, Small Block, Eachsorry i copyed the wrong one this is the one i was looking at what kind of numbers do u think i can be looking for i am still unsure what compression ratio i will be their stock cc is between 60.6-63.6 but mine have been ported not a whole lot but a decent amount plus they have been shaved like .20's what do u think
ORIGINAL: Jasperstang308
ikey did u do ur carb swap like u were talking about? have you got any numbers n/a?
ORIGINAL: jtmustang
CCA-35-440-8
CCA-35-440-8
that kinda sucks i just bought the heads and they were just out of the machine shop new springs 3 angle valve job magna fluxed and bead blasted i wonder how much or if they would charge me to figure that out
