lift ongt40p heads?
RE: lift ongt40p heads?
ORIGINAL: grabbem88
you are a site with me that proved me wrong about this
ORIGINAL: AdderMk2
Grabbem, the only problem with that is GT40P heads dont flow worth a damn past .500
well sure they work great on our mostly stock or mild cars.... but they arent GREAT....
Trying to use them on a car with 580-620 lift wouldnt be a very good idea... because they wont flow well.
But myself personally, the only reason I wouldnt use them, is the inconvience of the spark plug location.
first of all you don't always need lift to make power...my cam has small lift numbers and it screams..
tell ya what..like joel said...there are very good examples of what gt40's potential are...total package not peak values.
if you look at my peak numbers on my dyno sheet you would say something was wrong,but take it to the track and cut bottom 12's all day long..you would probably be scratching your head
If you have the stock springs....the exhaust side will bind @.510" lift.......you have to leave a .060" gap between the coil bind height of the springs and the actual lift on the valve....+ you need the spring rate requirements to support the cam lobe profiles and prevent valve float......upgrade them, it's long overdue....my 2¢.
when your trying to be able to get more lift from your heads without mechanical limitations the first step is the springs, followed in at a close second by having the guides machined down. otherwise the retainers will be smashing the valve seals or worse hit the top of the guide.
On the stock bottom end, you're "usually" limited to ~.530 max lift, if you are playing it safe. (<--not the end-all, say-all; but a decent guidelineto follow.Claying it up should be a must, IMHO!!)
As mentioned, the P heads don't flow as well over .500 lift, due to the 1.46 exhaust valves....do some work and upgrade the valves and you'll have a helluva set of heads.
Upgrading springs and valvetrain should be a given if you're working with stock components. I went w/ a Crane valve spring kit good to .550 lift for my ported E7's, even though I'm only running the E cam. Stock components aren't trustworthy and are 14+ years old on top of that.....
ORIGINAL: gspfunk
btw...
http://www.carbdford.com/tech/headflow.htm
ORIGINAL: my77stang
+1 on that too. even if you dont have the cash to get all new valves, the intakes are exposed to alot less heat than the exhaust valves and if you have the 1.84 intakes because they are GT-40 heads you can just get new exhaust valves in a 1.60 or even a 1.50 size along with some machine pocket porting on the intake and exhaust and you'd be quite happy with the outcome.
btw...
btw...
ORIGINAL: Joel5.0
But wait....I see them flowing better than the stock GT40's...and a few aftermarkets on the exhaust side, albeit the smaller exh valve.......it should be caused by other aspects of their design.....
That is what I've gathered from the info I've read/researched, but may not be the entire scenario....other factors may contribute as well.....
