AFR Heads ?
AFR Heads ?
I got a question, car is a stock 94 gt with 96K. I'm looking to get some heads and i'm not really sure what direction I should on in. I got a Trick Flow street heat intake and TF stage 1 cam already(not installed). My question is, will AFR 165cc stud mount heads work with the trick flow intake that i got? or should I go with Trick Flow twisted wedge heads. I got a bunch of parts that are going to be installed soon so i want to make sure I get the right heads to go with what I got.
The list of mods waiting to get installed:
3:73 gears
UPR throttle cable
Trick flow street heat intake
Trick flow stage 1 cam
Mac 1'5/8 long tubes cermaic coated.
3:73 gears
UPR throttle cable
RE: AFR Heads ?
normally i would say AFR's but with the TF cam and intake it may be better to use their heads so everything is matched. they DO dyno test their combos when they design them for a reason
RE: AFR Heads ?
ORIGINAL: my77stang
