map light fix?
RE: map light fix?
Forgive me I am not trying to hijack a thread, but mine does not work. I do know why though. The wire that runs inside fo the (ground strap I suppose) is shorted. If I pull the light down it shorts and pops a fuse. I disconnected the light a few years ago, because I have no idea on how to fix the internal wire. I have yet to find a replacement light. Has anyone got any ideas? or do you know if a place like 50 resto has replacement map lights yet?
RE: map light fix?
RE: map light fix?
i just installed a switch on it!! worked for me... i couldnt get that little contact piece to complete the circuit unless i was shoving it down really hard...
also here is the thread that i started
https://mustangforums.com/m_2808695/...tm.htm#2808695
RE: map light fix?
ORIGINAL: boof1027
http://www.ascmclarencoupe.com/Proje...htRestoration/
Try this it was posted a while back.....
Matt
Matt
Mine just simply had sh*t in between the 2 contacts and wouldnt touch-this might not be the case for other poeple, but i was glad to figure out mine was that easy- cuz so many people i know are like mine doesnt work so i just decided to try and fix mine
[IMG]local://upfiles/55564/C847FBF14B324221901648818F886D8D.jpg[/IMG]
RE: map light fix?
ORIGINAL: dillon1340
my headliner was bad so when i replaced it i took the map light out and just covered the hole up..i kinda miss that map light.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
