Whats the correct tooth speedo gear.
Old 03-18-2007, 03:13 PM
90Lxstanger
90Lxstanger's Avatar
Default RE: Whats the correct tooth speedo gear.
Hey Adder, sorry to specificllay bug you, but the VSS is basically the speedo cable right?, if so would me not having my speedo work be killing my computer/ a/f ratios/ economy?
Thanks, appreciate it
90Lxstanger is offline
Old 03-18-2007, 03:28 PM
Stanpower
Stanpower's Avatar
speedo gear.
Stanpower is offline
Old 03-18-2007, 03:41 PM
nitrous_bob
nitrous_bob's Avatar
no, the speedo gear or cable working or not working will only affect your speedo and odo , no computer problems
yes, the 23t is a jeep part, it is the wrong pitch for either the aod or the t5 it will chew up in some cases under 10k miles, they are white and they are junk
**** more speedo info just so people know
an aod car cannot be corrected past 3.27's , using a ford speedo gear, the 23t will work for 3.55's after that there is no option since the 8t drive gear is a machined on the tailshaft and not replacable (unless you wanted to find a different output shaft)
newer t5 cars have 8t drive gears '90+ so they are like the aod's but the drive gear is c-clipped on the shaft, you can remove the cover and replace it, some minor disassembly is required though, so if your having a t5 rebuilt, have them put the new gear on it then, get a black 6t to be safe, then you can be corrected for anything
'89 and older have 7t's but still can't get corrected for 4.10's w/out using a 23t or swapping the drive gear.
nitrous_bob is offline
Old 03-18-2007, 04:03 PM
tmajikman
tmajikman's Avatar
Thanks for all the help everyone.
tmajikman is offline
Old 03-20-2007, 12:28 AM
Infantryman
Infantryman's Avatar
Hello,
I would like some info about the spedo gear also. I have a 93 lx with aod andjust had 3:73's installed and the speedometer is off..used my gps. Which gear/color do I need, the guy at summit racing said something that I did not understand. Thanks
Infantryman is offline
Old 03-20-2007, 02:26 PM
goathead75
goathead75's Avatar
ORIGINAL: Infantryman
Hello,
You're toast. See the posts above, you can't correct past 3.27 with a 90+ auto using a Ford speedo gear. You can use the 23 tooth, which is a Jeep part, that will correct up to 3.55. The problem with that is, it will at some point get chewed up and you'll need another. Also, running 3.73's, it'll be close, but no Lewinski. You'll still be off between 5-10mph.
The other option, new output shaft = $$$$$$$
goathead75 is offline
Old 03-20-2007, 02:37 PM
Glasersil
Glasersil's Avatar
It's alot easier to use this:
http://www.atrol.com/era.htm
Glasersil is offline
Old 03-20-2007, 02:43 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Glasersil
hey glasersil.... maybe I can help you pull your head out of your butt.... pre 94 stangs had a mechanical speedometer.... not electronic
AdderMk2 is offline
Old 03-20-2007, 02:44 PM
goathead75
goathead75's Avatar
ORIGINAL: Glasersil
It would be, if he had an SN maybe. There isn't a speed sensor for the foxes.
Old 03-20-2007, 02:50 PM
Glasersil
Glasersil's Avatar
Yeah it's for 94-and up to keep from shredding gears douche. As in MY CAR! I'm just showing what I used on my car.
Quick Reply: Whats the correct tooth speedo gear.
