alternator possibly dead?
hey guys im pretty sure my alternator is dead. My battery isnt charging as it should while im driving, and inorder for my car to start, i must jump start it. It will start every time its jump started, but if left for several hours, it wont start, the battery either drains, or something. Anyone have an idea?
I've already checked the terminals for corrosion and made sure everything was tightly connected.
RE: alternator possibly dead?
Start your car and then disconnect your battery. If your car still runs then your alternator isnt bad. Also, do you have any other accessories? It might just be that your stock alt cant handle the load you are putting on it.
i dont have any other accessories, and it just started doing this. I just went out and tried to start it and just got
clicking. My dad is pretty sure its the alt and he can fix it, ive gotta go to work in a minute so i will letcha know how it goes. Thanks for the tips!
Put a voltage meter on the battery when the car is running and see what it says. Then see if it goes up when you rev the car, if it does its probably the alternator.
We took my friend's alternator to Advance Auto and Autozone and both of them said it was okay, but we replaced the alt and it fixed the problem, so they're testing is not fool proof.
Might just be the voltage regulator and not the whole alt that is bad. Test for a drain on the battery when the car is off and all the doors are shut/everything turned off.
