A couple timing questions
Old 03-19-2007, 04:22 PM
1985stang
1985stang's Avatar
Default A couple timing questions
I've been doing a lot of research on timing and i still have just a couple questions. I read through the search results and did not find answers.
1. Is the distributor hold down bolt the one bolt facing the front of the car that is at the bottom of the dizzywhere it attaches to the manifold?
2. Which wire am i supposed to unplug before adjusting the timing. My car is carbureted and all of the pictures i've seen have been efi. Are they the same?
3. Is 14 degrees an ok spot to start or should i start at 12 or even 10 (stock). I set my mark at 14 and it is a good inch away from the timing pointer. Is that normal?
Thanks for any input that you might have. I'd like to get this done soon.
1985stang is offline
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Soldier GT
08-12-2015 03:46 PM
StangMuscle
08-12-2015 07:27 AM
Quick Reply: A couple timing questions
