fuel safety switch info
well guys as most of you know i have been dealing with an issue for sometime now with my car completely cutting out between hard shifts between gears. after much research i have found the problem, in our foxes there is a fuel pump safety swich in the rear of the car. i have a hatchback so its inside the hatch located beside the taillight. there is a plug there and when removed reveals a reset button which is used to reset after a hard hit. this switch was designed so in the event of a collision in the rear, the fuel pump disengages as to not pump fuel out in the event of a ruptured fuel line. there is two magnets that have a ball in between them that connects the loop on the switch. as our foxes age this ball may get slop in it due to decreased magnet strength and what not causing fuel pump to turn on and off under normal driving conditions sometimes, like when a really hard bump is hit or any good jolt for that manner. thus when i strengthened my suspension for drag racing every time i shifted hard the ball was moving from in between the magnets and causing the switch to disengage and cut my fuel pump off which caused the cutout and as the car leveled out from decreased power the ball rolls back in between the magnets closing the loop again and resuming acceleration. so if you guys are ever experiencing cutting out or spudering and no apparent sensor codes reset the switch there and it could be the problem. like a say this is usually only a problem with high miles on the body itself. to fix mine i just wired the switch in constant closed loop and no more problems. just a little info for anyone who doesnt know.
RE: fuel safety switch info
i thought about it but being means most of the time i run my car on the strip rather than street because im 30 yearsold now and try to keep younger guys at the track racing rather than in the streets, i just bypassed it. in the event i do put it back on the street i will most certainly do this.
atleast i wasen't the only person having problems but i still am. ya i've replaced the switch and nothing helped my car but oh well. trying to figure out something tomorrow/rest of the week.
ORIGINAL: iceman89gt
whats up georgia, what problems you having.
it may be in the harness somewhere. start at the gas tank and work your way forward. where was the relay you changed
looks like im gonna be so busy this year i might not get around to it too soon but im moding my current 306 just for ****s and giggles. new maf setup and tb. also adding a AFR 4" power pipe rerouted to fender well and 30 lbs. injectors. but i was saying that start with the connection points on the harness before splitting the jacket and chasing wires down.
