Fuel pump keeps running???
RE: Fuel pump keeps running???
ORIGINAL: decipha
can't flood it if its fuel injected
the pump running continuously will NOT affect the starting or driveability of the car.. you have a different problem
any idea on what it is? I try to start it and it just makes this weird sound a few times. The only way i can describe it is like the vehicle is flooded.
Ok tried it( fully depressing the pedal while trying to start right?) Same thing happened. No start. I am going to check for spark and check my coil cause im running out of ideas. Ill keep everyone up to date. Thanks for all of the help so far.
If your pump keeps running its either shorted or you don't have pressure. If you don't have pressure more then likely the rubber hose that come out of the pump to the fuel line ripped. I see it happen all the time on many different cars and trucks. Your going to have to get a fuel pressure tester and check at the shreder valve for pressure and check right before the fuel filter.
when i turn the key on and let the pump run, I depressed the schrader valve and fuel shot out soi am pretty sure i have fuel pressure. I think im just going to go back to basics and check everything in the ignition systemm starting with spark.
