Whats with the smell?
RE: Whats with the smell?
A common misconception is that sulfur odor means the catalysts are bad. This could not be further from the truth. Catalysts fail in one on four ways: physical damage (car bottomed out on them), broken brick (rattles and chunks of it are in your muffler), meltdown (backpressure) and inefficiency (downstream oxygen sensor voltage mirrors the upstream). The odor you smell maaaayyyy be more prevalent if the catalyst melts or becomes inefficient but you would notice a power loss or have codes if that were the case. The sulfur odor is due to crap gas. Sulfur is naturally found in gasoline but is found in high levels in poor quality gas. Sulfur dioxide does not come from the internalcombustion event, rather from secondary combustion in the catalyst. This is why you never smell it vehicles without cats. Basically your cats are getting hot enough toburn the sulfur in yourcrappy fuel. It is possible to smell this more often if your cat is running at an abnormally high temperature. Most of the time it meansthe arab you bought gas from sells cheap fuel. Put a few tanks of good stuff through it and the smell should goaway.
bradleyb
11-27-2015 07:50 PM
