Fuel Pump Relay
RE: Fuel Pump Relay
isnt the fuel pump relay that white button that u can press and that cuts the fuel off if u get into an accident? cause if it is then mine was in my trunk area behind the panel that u take off to take the tailights out on the driver side.
RE: Fuel Pump Relay
no that is the fuel pump cut off. like you stated in case you get into a rear wreck
ORIGINAL: 87mustang347
RE: Fuel Pump Relay
It is definetly not under the seat. Had the seat out and it is not there. There are relays under the hood but they don't look like the replacement part that I got. The car does run. That is why I'm not sure about the code.
RE: Fuel Pump Relay
its in the fuse box under the hood. Its the black looking cubical looking fuses under there. They should have a ford Emblem stamped on the tops. If your having trouble with your fuel pump not cutting on and you think its the relay, just take one of the others out, i believe there is a blower motor relay, take that one out and trade it with the fp relay and see if it cuts on then. Then you'll know if its a relay or not.
Good luck.
Good luck.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
