Son of a B*$ch!
Old 03-23-2007, 08:55 PM
campbellsoup24
campbellsoup24's Avatar
Default Son of a B*$ch!
I just took my car out today, first time since Sept. Everything was going fine until I pulled out of the gas station. I pulled out in front of a car that was going alot faster than I thought! I changed into second kind of hard to get moving and the gear grinded alittle, I figure no big deal its happend before? Well now everytime I try to put it into second it won't go, all it does is grinds bad,I can get it to go, but not without jamming it in! Anyone know what it is, or what it could be? I have new clutch soI know its not that. All the other gears are fine, and whenI am stopped and put it into second it's fine too?
I have a 93 Gt 5 spd.
Any info would be great!
campbellsoup24 is offline
Old 03-23-2007, 09:02 PM
pastang
pastang's Avatar
Default RE: Son of a B*$ch!
syncro?
pastang is offline
Old 03-23-2007, 09:05 PM
nasty50
nasty50's Avatar
most likely the tranny.......i had the same thing happen to me a while back with third gear. it was my only car so i kept driving it and within a week i didn't have 3rd or 4th gear. the stock t5's are really weak, and i don't think its woth spending the $ on a rebuilt ($600-$1000), instead get a tko or a junkyard t5 if your tight on $.
nasty50 is offline
Old 03-23-2007, 09:08 PM
frdmstng1986GT
frdmstng1986GT's Avatar
could be a syncro, deffanitly sounds like it. Also could be a broken pilot bearing maybe since you just got a new clutch put in. sometimes they break if they arent lined up perfictly.
frdmstng1986GT is offline
Old 03-23-2007, 09:09 PM
Mikes Stang
Mikes Stang's Avatar
Sounds like a blocker ring. (Placed in front of the sychronizer. Has a liner on it that goes out with age/abuse. Once the liner goes, the synchros don't mesh.) Best way I know to explain it. Probably not 100% right, but its the general idea.
Happened to me before in almost the same way. Pulled out in front of someone, nailed it, ground second and blew the blocker ring.
Mikes Stang is offline
Old 03-23-2007, 10:16 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
yea that diffenetly sounds like a syncro problem... i agree with the other fellas... dont use 2nd gear until u get it check out... so 1,3,4... its a pain im sure but if it in the syncro then ull only make it worse by jamming it in there
CrazyCobraSpeed is offline
Old 03-23-2007, 11:07 PM
BlazeGT
BlazeGT's Avatar
Talk to coupe94gt. He does a lot of work with trannys. I was gonna have mine rebuilt by him, but im prolly going with a new tranny for the project im building. As far as i know, he's very knowledgable when it comes to trannys.
BlazeGT is offline
Old 03-24-2007, 12:07 AM
boof1027
boof1027's Avatar
+1 He rebuilds t-5's and Dimebag is another one with alot of tranny knowledge.
boof1027 is offline
Old 03-24-2007, 12:58 AM
94gtcoupe
94gtcoupe's Avatar
PFFTT dimebag? that guy don't know anything lol j/k yea he knows a good amount..
any way u may have bend a shift fork, more than likely it's the syncro... try to adjust the clutch a little tighter and see if that helps the clutch might not be releasing all the way so that could of caused it to grind in the first place...
and nasty the STOCK T-5 is stronger than u think it is, i have personaly seen them take mid 10 runs constantly
ORIGINALL: boof1027
yea the blocker ring is PART of the syncro, and yes it has a line that goes out with normal driving and slightly faster when abused.... but the liner only help the syncro to no ware as fast, not having the linerWON'T make is not mesh
ORIGINAL: Mikes Stang
94gtcoupe is offline
Old 03-24-2007, 01:02 AM
Boosted5.slow
Boosted5.slow's Avatar
see mine was doing the same thing last week.but i got under the car and foud that the clutch cable was fraying apart.
Boosted5.slow is offline
Quick Reply: Son of a B*$ch!
