Need a favor..adding a VSS
I got my new sensor and a new pigtail plug from ford today..figured it would be an easy install match the wire colors, and boom, all set...wrong. I got the plug out and both wires are white. I don't know which goes to what side, goes where. Orange/yellow is one wire in the harness and the other is green/white. Is there a right and wrong way to install this plug or what?
If someone could take a picture of their sensor, with the plug in it so I can see the wires and position of the plug, I can figure it out.The VSSis mounted on the end of the speedocable, attached to the tranny.
THANKS
THANKS
RE: Need a favor..adding a VSS
Ok, I don't need apicture of the speed sensor anynmore..now I found out the colors, but still not what I wanted to see(not the same as the ones I had to splice into for my computer..). I need a little bit more in depth picture, under the drivers side kick pannel, there is a black 8 place plug that the sensor is wired into. I need to see that so I know where to hook my wires up to.
I am, damn demanding huh...
edgespeeder06
09-23-2010 06:19 AM
