performance help...
Old 03-22-2007, 11:54 PM
richard4221
richard4221's Avatar
Default performance help...
do i need mufflers in my exhaust or can i stick with bbk shorty's and magnaflow bullets....they are just pipes, no converters or mufflers....will long tubes higher my performance or we dont really need it...
richard4221 is offline
Old 03-22-2007, 11:56 PM
ooticamitica
ooticamitica's Avatar
Default RE: performance help...
if you dont have mufflers it will sound like ***. and long tubes are more for built engines so just use shorties.
ooticamitica is offline
Old 03-22-2007, 11:59 PM
DIMMER
DIMMER's Avatar
The Myths:
Longtubes will lose low-end power/torque on a stock mustang.
Mike Hudson - I went with the ever too big 1-5/8" LT's on an otherwise factory original 5.0 and gained hp and tq all across the board. A min. gain of 5hp/tq was seen at 2000(where the pull started) and paeks of 15.2hp and 14.7tq were recorded. Peaks were up a mere 100rpm for hp and 200 rpm for TQ. Dynos are neat and all, so, at the track, with the extra hp and rpm I gained a soild 3/10ths and 2mph.
I took that from anouther mustang tech site.
I just found that interesting. since my lil 3rother has 3 f-bodys and hes building one up and they same the same for LT1's lol
DIMMER is offline
Old 03-23-2007, 12:00 AM
uni_uni
uni_uni's Avatar
Keep mufflers, depending on where you are you could get an H-pipe without cats but definatly keep the mufflers.
[/align]
uni_uni is offline
nitrous_bob
nitrous_bob's Avatar
yes you need mufflers, it will run slower from no backpressure.
reduced backpressure is good, none is bad
i disagree on the longtubes, i'm using them for the second car. i say do it. plus they sound way better.
my '89 went went 13.20's w/ just longtubes, 4.10's, ac and smog delete
nitrous_bob is offline
Old 03-23-2007, 12:02 AM
richard4221
o.k. i have the bbk shorty headers only and i think its hooked up to the stock h-pipe and then the magnaflow bullets....why did you get the all american thunder cat-backs for???performance???thats what im trying to get at...dont you need restriction so that you can burn your exhaust instead of running lean because of my set up...
Old 03-23-2007, 12:12 AM
86 GT 5.0
86 GT 5.0's Avatar
Running lean doesnt have to do with your exhaust it means you not getting enough fuel... If i were you I would just throw an off road h or x pipe on and call it a day since you already have headers and a catback...
86 GT 5.0 is offline
Old 03-23-2007, 12:18 AM
richard4221
no i dont have a catback just bbk shorty headers, stock h-pipe, and magnaflow bullets....will i be o.k. with that....or can i gain hp by putting mufflers and then longtubes...
Old 03-23-2007, 08:47 PM
richard4221
bump
Old 03-24-2007, 04:18 AM
5pointslow91
5pointslow91's Avatar
headers, xpipe and mufflers, your making it complicated, with long tubes you run the risk of denting them up on a daily driver with bump and ramps
5pointslow91 is offline
Quick Reply: performance help...
