What kind of potential
My Project 1992 Coupe has a built 347 stroker with TFS Track Heat heads and intake, longtubes, 75mm Accufab TB, MSD ignition, FMS "F" cam, 3.73's and full suspension. What kind of times can I expect? With street tires, shorty headers and stock suspension...the car ran a 13.7@112mph with a 2.4 60'.
I am wanting a solid 10 second N/A car. Are the 347's capable of these kind of times or should I scrap it and put a carbed 408 in it? I am still learning on these 5.0 push rod motors. Thanks in advance for your responses.
RE: What kind of potential
ORIGINAL: thunderjet429
112mph... you should already be in the 12's... must have traction issue.
There are alot of little factors... compression, location, tires, and 1000 more than I dont know about. A well built 347 should put you pretty close to your goal.
Sleeperstang... there are guys inthe 9's running NA 306's! I would say your 347 stroker motor could dip 10's if you tried hard enough w/ the right parts selection... Im not one to give out advice on that though.
LCDBlackDeep.... no reason for him to have to go carbed.
treesloth
09-28-2015 07:03 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 06:42 PM
zanemoseley
09-06-2015 12:58 PM
