header install issues
Old 03-23-2007, 05:00 PM
N8_FIVE.O
N8_FIVE.O's Avatar
Default header install issues
Pleeez help. I am going out of my mind.... Installing BBK Equal length Headers... Dirver side is hitting my steering bar/knuckle and I cannot line it up.. Ideas...
N8_FIVE.O is offline
Old 03-23-2007, 05:05 PM
Force4
Force4's Avatar
Default RE: header install issues
eeek. you should be able to determain if it will even fit with it being blocked by bar. if its just blocking you from the install why dont you just remove it for now?
Force4 is offline
Old 03-23-2007, 05:14 PM
TwotoneVert
TwotoneVert's Avatar
Not sure, be patient, there will be someone chime in soon. If the steering linkage is in contact after the install, you will need to replace your engine mounts, not a big deal.
TwotoneVert is offline
Old 03-23-2007, 05:20 PM
N8_FIVE.O
N8_FIVE.O's Avatar
Thanks Two tone... i called BBK and they said that:
1) move the dash over....unbolt 4 bolt and just move the dash over.
2) I need new motor mounts... it is 19 year old car afterall...
this is gonna be a nightmare...
I like that hood.. it is the Mach III?
Old 03-23-2007, 05:22 PM
88BlueGT
88BlueGT's Avatar
I would go for the motor mount idea. Its never a bad thing to replace them anyway. Especially if they are the originals.
88BlueGT is offline
Old 03-23-2007, 05:32 PM
TwotoneVert
ORIGINAL: N8_FIVE.O
Yes, its theMach 3.Replacing themounts are not too bad. Just unbolt and jack up the engine far enough toclear the mounts. Swap them and lower the engine back on the mounts. Just DO NOT use the oil pan to lift the engine!
Old 03-23-2007, 05:33 PM
Trainman
Trainman's Avatar
Had the same problem, I replaced the steering shaft and it still rubbed a little.( flaming river)Then I installed new motor mounts, that took care of it.
Trainman is offline
Old 03-24-2007, 04:24 AM
5pointslow91
5pointslow91's Avatar
you could also dimple 1 or 2 of the tubes that are rubbing, HP ud lose wouldnt be enough to even notice, very minimal
5pointslow91 is offline
Old 03-24-2007, 09:13 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 5pointslow91
Don't do that!!
I had the same problem. If replacing your mounts doesn't solve it, jack up the left side of the motor and shim the mount w/ some washers. That's what I did, problem solved.
PRO50SC is offline
Old 03-24-2007, 09:27 AM
grabbem88
grabbem88's Avatar
if it's hitting then the two old guy's are right...i had broken pads,and couldn't get my shorties on....now i have long tubes which resulted in removing the shaft so it can go through the headers...fun fun.
grabbem88 is offline
Quick Reply: header install issues
