did a compression check.....
as it says, i did a compression check today and the needle on the psi meter i watched go from 0 to about 110 then to 145 then to 150 and going NO more than that. 150psi, is that normal?? i know if the needle falls below the max psi then on every other turn goes higher then the rings are worn and need to be re-done.
what is everyones thoughts???????
uberstang1
09-20-2015 06:42 PM
