disconnected IAC valve..
Old 03-23-2007, 09:36 PM
settled4automatic
settled4automatic's Avatar
Default disconnected IAC valve..
ok, so my '88 gt idle's anywhere from 2000-3500 rpm's when it gets warm. is it alright to drive around with the IAC disconnected until i can replace it??? might be tomorrow, might be monday... just curious if that would hurt anything. your thoughts?
settled4automatic is offline
Old 03-24-2007, 12:04 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: disconnected IAC valve..
wont hurt anything. the iac is just to help keep the idle smooth. if the car idles without it, itll be fine
luckythirteen13 is offline
Old 03-24-2007, 12:05 AM
5.0stanger
5.0stanger's Avatar
When you car is cold, you may have a stalling issue, but you will be fine like said above. I ran mine without for a few weeks till i figured out my hanging idle problem.
5.0stanger is offline
Old 03-24-2007, 04:43 AM
settled4automatic
ORIGINAL: 5.0stanger
so the IAC valve wasn't the cause of your hanging idle problem?? i'm planning on getting a new IAC tomorrow and throwing it on, because the car drove fine all tonight without it plugged in, leading me to believe that there isn't anything else causing my high idle.
Old 03-24-2007, 07:43 AM
5.0stanger
5.0stanger's Avatar
My base idel was set too high. As funny as it sounds, I just unhooked the IAC, turned the idel screw down till is just barly ran and stalled, re set TPS, re connected my IAC and my problem was fixed.
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
lmurf60
09-24-2015 10:07 PM
TfcCDR
09-14-2015 12:08 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: disconnected IAC valve..
