oil pressure guage
Old 03-24-2007, 01:00 AM
Boosted5.slow
Boosted5.slow's Avatar
Default oil pressure guage
89 5.0 mustang i recently put a new motor in and it has 348 miles on it. i noticed after i drive around for awhile my oil psi is fine but when i stop at a light the psi goes down to about the secound bar on the guage. any ideas
Boosted5.slow is offline
Old 03-24-2007, 01:02 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: oil pressure guage
It's normal for it to drop at idle. You should check it w/ a mechanical gauge to be safe.
PRO50SC is offline
93 LX FiveO
93 LX FiveO's Avatar
...what kind of gauge? stock?
get a aftermarket (autometer)
93 LX FiveO is offline
Old 03-24-2007, 01:11 AM
Boosted5.slow
Its the stock guage. it just started to do it to maybe sending unit is going south?
Old 03-24-2007, 01:17 AM
Grundy
Grundy's Avatar
replace the sender. they are cheap....if that dosent fix it test it with a mechanical gauge and hope for the best. sounds like an oil pump or oil pump pickup problem....but if the motors only got 348mi on it that shouldnt be the case
Grundy is offline
Old 03-24-2007, 02:49 AM
gr84u
gr84u's Avatar
AVOID OIL problems! I just blew mine up because I didn't bolt my pump back tight enough, and ignored my gauge, thought it was a bad signal. I was WRONG! 2 blown con-rods later, but now I learned and have a 306 ready to fire up this weekend.
gr84u is offline
Old 03-24-2007, 03:04 AM
92cobra
92cobra's Avatar
start simple mate, make sure theres enough oil in her.
92cobra is offline
Old 03-24-2007, 03:53 AM
red89fiveO
red89fiveO's Avatar
i had the same problem when i swapped engines... only my gauge would only go up when i was above 1500 RPMS... anytime i was below that it would go below the like it was off.... replaced it with autometer gauge and its fine...
red89fiveO is offline
Old 03-24-2007, 04:14 AM
stang2race
stang2race's Avatar
ORIGINAL: Boosted5.slow
Not cool to play with your cars blood presure, get an aftermarket guage with some numbers. That is the most annoying thing ford did with those dumb bar guages.
stang2race is offline
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
wraith777
09-28-2015 10:49 AM
SteelerNation82
09-16-2015 07:11 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: oil pressure guage
