1994 mustang dies when hot
Old 03-24-2007, 03:41 AM
Jaymustang04
Jaymustang04's Avatar
Default 1994 mustang dies when hot
94 5.0 starts up and runs fine when cool for about 30-45 minutes when hot car will either cut off or or when car is turned off it will not crank or it will run for a few seconds and dies when it begins to idle. i have two trouble codes, 314 and 311. 314 AIR system inoperative during KOER ( bank number 1 with dual heated oxygen snesors) and 311 AIR system inoperative during KOER (bank number 2 with dual heated oxygen sensors). i do not know were to start fixing the problem so of anyone can help or have any idea please help me out.
Jaymustang04 is offline
Old 03-24-2007, 06:52 AM
92cobra
92cobra's Avatar
Default RE: 1994 mustang dies when hot
Well good sir. Your fix in my opinion, which is absolutely worthless most of the time is very simple. You need to change your..............hmm.....uh............oxygen sensors?
Thats the first place i would start. I'm not sure if you have a tfi moduel on your distributor, but if you do, change that just for the hell of it.
92cobra is offline
Old 03-24-2007, 07:00 AM
grabbem88
grabbem88's Avatar
that's what i was going to say...module or pick up
grabbem88 is offline
Old 03-24-2007, 09:32 AM
AdderMk2
Banned
AdderMk2's Avatar
TFI modules are not on the distributor on the SN-95's and its less than likely to be the culprit... However it is a cheap place to start
AdderMk2 is offline
Lee1911
09-01-2015 02:12 PM
jesse1125
08-25-2015 05:52 AM
Philhampton1
08-21-2015 12:04 PM
daytooday
08-11-2015 09:22 AM
elraun
3.7L V6 Technical Discussions
08-09-2015 04:32 PM
Quick Reply: 1994 mustang dies when hot
