broken bolt on valve cover???
went to repalce my valve cover gaskets this morning and I think one of the bolts is broken off...passenger side, back lower bolt...by the engine hoist bracket...is this a special bolt or is it broken? I cant tell...how hard is it to tap that sucker outta there? size?
RE: broken bolt on valve cover???
remove the engine hoist bracket and the rest of the other valve cover bolts, then remove the cover and gasket. if the stub of the bolt is sticking up, you can try using some Vice Grip pliers on it to remove it. if it's broken off down in the head, you will need to use a screw extractor or "Easy Out" to remove it after drilling a hole in it for the extractor to fit into. these are small bolts, so you need a small size extractor and drill bit.
good idea...I think that will work cause it looks like its at least broken where its flush with the top lip of the vc...thanks again roundman! wish me luck..my girl says I gotta rake the leaves first....ugh...
ORIGINAL: vfast
sometime you can notch the bolt and use a screwdriver to back it out as I thing there might only be 15 pounds of tq on the bolt
couldnt get it out with vice grips...Im gonna try to notch it and back it out with a screwdriver....what should I notch it with? or is it just as easy to use an extractor?
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
