more noob cam questions
Old 03-24-2007, 05:59 PM
fivepointoh
fivepointoh's Avatar
Default more noob cam questions
Im putting in the e303 and trickflow manifold.
what springs would be good for the setup?
1.7 or 1.6 rockers?
and are all timing chains created equal?
fivepointoh is offline
Old 03-24-2007, 06:17 PM
my77stang
my77stang's Avatar
Default RE: more noob cam questions
im curious if anyone on here has ever used the 1.7's on the ex and 1.6 on the intake to obtain a dual pattern setup.
no, all timing chains are NOT created equal. you should be spending between 50 and 75 bucks for a decent TRUE double roller timing chain.
not sure about part numbers for the springs, but i would think with an E cam you'd want around 120 lbs of seat pressure.
my77stang is offline
Old 03-24-2007, 07:36 PM
90Lxstanger
90Lxstanger's Avatar
ORIGINAL: my77stang
I read and article on that actually, said that a full set of 1.7s doesnt do anything for the engine, but when you mixmatch them it does give a gain in hp, its just weird though, that and read also you need to make sure when you run 1.7s that you have the correct length pushrods.......
90Lxstanger is offline
Old 03-24-2007, 08:28 PM
VigCS
VigCS's Avatar
ORIGINAL: my77stang
ZachW04Stang was talking about doing this when we went junkyarding last weekend.
VigCS is offline
Old 03-24-2007, 09:14 PM
LIL D
LIL D's Avatar
how would 1.7 not help if you can find the link i wouldnt mind reading it
LIL D is offline
Old 03-24-2007, 09:37 PM
Joel5.0
Joel5.0's Avatar
Lift and Invigorate 1.6 vs 1.7
Joel5.0 is offline
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: more noob cam questions
