65mm tb or 70mm tb????
RE: 65mm tb or 70mm tb????
if you can feel the difference your on crack
ORIGINAL: backfire2007
I just swapped myBBK 65mm for a polished 70mm
it looks better andthere is a small difference.
but ifyou got h/c/i you should definately 70mm+
F/A I find it hard to believe a dealers of hipo parts would steer this guy wrong...no mention of any type cam or much of anything else..hell he may have the stock maf..also people might buy stuff if you post your real name..
ORIGINAL: FullAuto
Since you have it, use it. When you upgrade, buy a 75mm.
probably they have just had a 3 angle valve job new seals blasted and tanked now they have a fresh squirt of ford blue they have also been ported and shaved like.025's so they will add some decent horsepower to a good motor
I'd call it a push. If you are using a long-runner intake, I'd stick with the 65, since you have it. Intake velocity is more important thanvolume for a long runner, non forced application. Additionally, the throttle responce will be more driveable. Just my opinion.
