Turning Signals...again
i replaced the round fuse found under the steering wheel, but my turning signal lights still do not work. again my lights, and hazardous work very well it is only my turning signals that dont. at first they would flash very weak then they just stopped working...
RE: Turning Signals...again
o.k i'm not real mustang savvy but i've had this particular problem. your replacing the wrong flasher, you replaced the hazard flasher is on the fuse panel. look on the passenger side under the dash next to the radio don't expect it to be metal though. mine was plastic and blue............. if you still have the one you took out it will work if your hazards were working before change
Not trying to take over this thread but I'm having the same problem, but mine actually don't work. I just bought the car and the previous owner must have done some hackjob under there and now the lights stay on if the blinker lever is hooked up. Anyone know what the hell is going on?
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
