White Smoke...Help.... - MustangForums.com
Old 03-25-2007, 09:35 PM
AJRabbit
Default White Smoke...Help....
I recently did my lifters and adjusted my rockers. upon finishing the job, i ran the motor for a about 1/2 hour to reset the computer and check for leaks/ fluid levels. everything was fine. as i was driving home, a lot of white smoke was coming out of my exhaust. it was like a fog was forming behind me. my fluid levels are full after 2 days. what can this be? i also did new plugs, wires, cap,rotor, 14degree timingand MAC headers. please help. im very confused.
thank to all in advance
AJRabbit is offline
Old 03-25-2007, 09:50 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: White Smoke...Help....
Well, generally white smoke = blown head gaskets.[:@] Or coolant is somehow getting into the combustion chambers. What all did you have apart?
PRO50SC is offline
Old 03-25-2007, 10:05 PM
AJRabbit
i havent lost any coolant fluid, overheated, and it doesnt smell like coolant. would it happen quick like that? whats a good way to check if its true. i drained my oil today after it sat all night. no water/coolant. should i remove the plugs and pressurise the radiator?
AJRabbit is offline
Old 03-25-2007, 10:08 PM
AJRabbit
i took off the u/l intake, rockers, lifters, exhaust, a/c compressor, plugs, distributor, but not the heads. i had to change my lifters because they were bad. so i did a normal replace of them, adjusted the rockers, and put the assembly back together. it doesnt leak anything or smell like coolant or gas.
AJRabbit is offline
Old 03-25-2007, 10:35 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Maybe you didn't get a good seal on the coolant passages of the intake. Is it still smoking?
PRO50SC is offline
Old 03-25-2007, 10:52 PM
LTnone
Didn't take the throttle body/egr/upper intake apart, did you?
LTnone is offline
Old 03-25-2007, 10:56 PM
cassidymustang
You didnt take off your heads? sounds like coolent getting in somewhere
cassidymustang is offline
b8checker
10-08-2015 01:55 PM
breaking
10-02-2015 02:27 PM
14gt_Track
10-01-2015 03:47 PM
b8checker
09-30-2015 08:11 AM
MacSerio
09-27-2015 02:05 PM
Quick Reply: White Smoke...Help....
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
