Knock in the bellhousing HELP!!!!
I just did a swap and when i started it up there is a knock coming from the bellhousing its continous knock i know its not in the motor and my clutch pedal is really far up can anyone help me out
I have the same problem. I replaced all components except the pilot bearing and now I have a loud knock when the clutch is released. It goes away when the pedal is pressed. And looking through the side of the bellhousing it looks like the throw out bearing wabbles
i got the same problem, i believe it is a warn out clutch fork, the clip that the Throw out bearing slides onto isnt as tight as it should be, just replaced everything from the flywheel back besides that (even pivot ball) so thats my guess
whatever it was that you swaped, It's probably that.
I had the same problem, it was a worn out pilot bearing
