cam installation
RE: cam installation
ORIGINAL: 86 GT 5.0
^^^ way to help him out... I'm sure he got great info from that...
it costs 40 bucks, for intake gaskets and coolant and a timing chain cover. seriously look into doing it yourself. go buy a hayes or chilton's manual on mustangs. also look online, it's called a search. easy to do. you can borrow the tools like a balancer remover from autozone. if you have problems along the way, just post em on here and it'll be answered.
You won't notice as much of an increase if you just stick the cam in with stock heads, but at the same time, if you have the cam, theres no real reason to wait... Its not complicated, just somewhat time consuming if you have never done it because of the extra care you give trying not to mess anything up... You'll get a lot more satisfaction out of your own work... Good luck
http://forums.stangnet.com/showthread.php?t=533159<<<DOESNT GET ANY BETTER THAN THIS
this is for h/c/i swap if your only doing the cam just leave out the heads part good luck
Luke9222
10-22-2015 11:55 PM
