Recommended Tire Pressure
Old 03-27-2007, 01:16 AM
PC696
PC696's Avatar
Default Recommended Tire Pressure
Need some help from anyone that can. I just replaced the ten-hole 15" wheels on my '89 LX with the 16" star Pony wheels (with 225/55/16). The max pressure on the tire is 44 PSI. Can anyone advise what the door decal recommended tire pressure is for these? Thanks!!
PC696 is offline
Old 03-27-2007, 01:19 AM
HACKGT350
HACKGT350's Avatar
Default RE: Recommended Tire Pressure
safely i would do 32-35 psi you should be fine
HACKGT350 is offline
Old 03-27-2007, 01:21 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: HACKGT350
Yup, no more though.
PRO50SC is offline
Old 03-27-2007, 01:24 AM
PC696
PC696's Avatar
Thanks, guys...I leveled them all to 35 when I got it from the shop today, not knowing what to do. I appreciate the help!! This is a great forum. I am hoping to start a complete reconditioning this summer, to adding the wheels was my first step to giving my car a "rebirth."
I'm going to be moving to the Greensboro, NC area in the next few months, so anyone in that area that might be able to give some advice would be great.
Later...
PC696 is offline
Old 03-27-2007, 01:26 AM
HACKGT350
HACKGT350's Avatar
got anypictures of your car?
Old 03-27-2007, 02:03 AM
dimebag
dimebag's Avatar
i always go w. 32, seems to work the best..
dimebag is offline
Old 03-27-2007, 02:11 AM
mustangguy82
mustangguy82's Avatar
30 in front and 26 in rear these cars are light in the rear
mustangguy82 is offline
Old 03-27-2007, 02:16 AM
dimebag
dimebag's Avatar
yea dont listen to that guy... do 30-35 all the way around... se how they wear... if the center is wearing but not the edges, less air is needed... if its the other way, use more...
dimebag is offline
Old 03-27-2007, 02:21 AM
94gtcoupe
94gtcoupe's Avatar
for the SN95's ford reccomends 35 in the front and 32 in the rear, so subtract 200lbs or so and thats about 34-33 up front and 31-30 in the rear... but like dimebag said start at one place and see how the tires wear and then adjust them from there
94gtcoupe is offline
Old 03-27-2007, 02:30 AM
mustangguy82
ok dont listen to the tire guy, i used some chalk on my tires and 30 in the front and 26 in the rear is were they wore the chalk off even. its not like i just magicaly came up with those numbers[sm=signs003.gif]
Quick Reply: Recommended Tire Pressure
