differential question
RE: differential question
...What he means is lift the car, mark a spot on your tire and your drive shaft.... then turn the tire one full revolution and count the revolutions the driveshaft makes... For example, if you turn your tire once and your drive shaft turns about 3 3/4 turns, you have 3.73's... etc etc
You can do that too, and more than likely it will be stamped into the ring gear if it has a good grade ring and pinion in it... If you didn't want to pull the cover, the other way would be much quicker, but it would be a good time to go ahead and change the fluid in the rear end....
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
KingRando
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
