RPM stay up
RPM stay up
Hey guys I just finished cleaning my IAC and adjusting my TPS. There is still a problem when the clutch is depressed and let off the gas the rpms stay up for a few seconds before they drop. Normally in any other car I have been in, when you let off the gas the rpms come down immediately. So if someone could tell me what I could do that would be greatly appreciated. I could only get the tps to 0.97 but I don't think that is an issue. Thanks
RE: RPM stay up
ORIGINAL: Streetracer911
any idea where?
ORIGINAL: frdmstng1986GT
vaccum leak. start lookin.
RE: RPM stay up
propane does work.. but you better hope to god that you dont have any arching plug wires or anything like that or you will blow yourself up. i just use carb cleaner.. little messier but it always worked for me.. same thing with starting fluid.
RE: RPM stay up
OK, just b/c you cleaned the iac doesn't mean it's functioning properly. Something to keep in mind. How long does the idle hang? If it's a very short time, second or 2, it's normal. The ecm has to have time to react and adjust the iac.
RE: RPM stay up
ORIGINAL: PRO50SC
