A fuel ? I have not yet read about!
My car has ported and polished heads, headers, throttle body, cam, new fuel pump, and larger injectors. My question is; When I am off Idle and release the throttle it dies. I was told that it is running rich and putting out the fire. Which I belive. Can I fix the problem temporarely by putting the stock injectors back in? I'm looking for a temp fix until I put the suppercharger on it latter this year and have it tunned.
Thank you all for your help!
The Beav
The Beav
RE: A fuel ? I have not yet read about!
It sounds like that's exactly what the problem is. Change to stock injectors. That combo isn't nearly enough to warrant anything larger than the stock 19# units, especially with a higher capacity fuel pump.
Change to the 19# injectors and recalibrate your MAF (if you did in the first place) and you should be alright.
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
