door stuck shut
RE: door stuck shut
seems like your accumlator is bad. this is what locks and unlocks a power lock door. you will need to take off the panel to get to it. remove the few screws that holds it on then remove the large screws in the arm rest then slighty tug on the panel about every 5 inches to undo the push clips
RE: door stuck shut
real common problem happeneds to alot of mustangs take the top cap off for ur door lock button and grab the rod with a pair of vicegrips and pull up happends all the time to my car i greased it with white lituim grease and it works good now seems to only act up in the winter months,
RE: door stuck shut
alright i'll go do that right now, just that my lil pocket that holds stuff on the pannle, its old and streched, so its closed into the door, makes it hard to get those clips, but i'll give it a go, thanks alot
breaking
10-02-2015 01:27 PM
09-25-2015 06:58 PM
