Carbon Fiber Drive Shaft
I am pretty excited about this one. My buddy manufactures Carbon DS. He is going to begin one for the Fox's. I will let you know when I get it with some Dyno charts.
RE: Carbon Fiber Drive Shaft
You're not buying one, are you?
ORIGINAL: LTnone You're not buying one, are you? |
carbon fiber driveshaft?????????????????is this fo reallll?????
pretty unkillable when built rightand make a noticable difference on some cars, be interesting what difference it makes on a stang.
weve been asked to test one for another car, company is claiming it transforms the car, i know it makes a fair difference from the drag cars i know thats used them, but im sceptical about it transforming it, surely no more than shaving the same amount from a flywheel would. well actually, now i put it like that, you take a LOT more weight off the shaft than you do off a flywheel, so hmm, it may well make a fair huge difference. usually damn expensive though! |
id have a hard time trusting it... eevn tho they prob are stronger... id be scared to launch like a mother ****er off of it
ORIGINAL: Steve13380 be interesting what difference it makes on a stang. |
well about the strength, i can think of a few on 1000bhp+ 4wd drag cars on full slicks, and they seem to last well, some of these companies offer warrentys as they so convinced it wont break.
sure itd change things a lot more than aluminium, will weigh about half that even with the metal ends, but how much, who knows |
ORIGINAL: dimebag id have a hard time trusting it... eevn tho they prob are stronger... id be scared to launch like a mother ****er off of it The new Boeing 787 is going to be an all composite fuselage. I think a ds can be designed to handle some hp... If possible please answer the following... I am curious... Are these going to use epoxy resin? Vac bagged? Autoclaved? Prepreg? I assume the guy has a mandrel and can filament wind the shaft... How are the u-joints to be attached? jason |
II know they do vacuum seal, but ill have to hit him up on which process it actually is. It is not a sheet of carbon, the carbon is thread and wound. The yolks are CNC Billet. There is a lot less rotating mass. I saw a dyno run on a 500hp Sti, basically the shaft allowed to get to max HP and TQ faster and much steadier...if that makes sense. But I will keep you guys updated.
