SPRING BREAK
its now springbreak and time to start working on my stang[sm=happy046.gif]
im pullin the engine from my 88 and putting it in my 86 cant wait to get started |
RE: SPRING BREAK
go get a 12 pack, call some buddies and start tonight!!!! i would have to say that that sounds real nice right now.
RE: SPRING BREAK
well since im 16 i dont think the 12 pack would be a good idea :D, and the 88 aint at my house yet. Im pullin it home sunday
RE: SPRING BREAK
sounds like your gunna be having fun
RE: SPRING BREAK
ORIGINAL: I3atR!ce go get a 12 pack, call some buddies and start tonight!!!! i would have to say that that sounds real nice right now. |
RE: SPRING BREAK
wish i could start tonight. sucks that i cant
RE: SPRING BREAK
might wanna take engine and tranny out together, pre soak the header studs( most likey will have to be cut off) and the driveshaft bolts with penetrating oil.
If you just take the motor out, alignment of the motor and trans will make it harder on your time. and supporting the trans while the motor is out. Make sure the ground is smooth and flat, if not the wheels will get stuck for the floor jack. Remove the hood and go slow with everything |
RE: SPRING BREAK
^ +1
Header bolds are pains in the ass. Soak the motor mount bolts also. Taking the hood off is the only way to go. When you are actually pulling it out go very slow! A tranny swinging into the windshield is a very bad experience. |
RE: SPRING BREAK
ORIGINAL: boof1027 ^ +1 Header bolds are pains in the ass. Soak the motor mount bolts also. Taking the hood off is the only way to go. When you are actually pulling it out go very slow! A tranny swinging into the windshield is a very bad experience. |
RE: SPRING BREAK
that would depend on if it was your windshield...
