k member help
Old 04-02-2007, 12:03 AM
five0fm
five0fm's Avatar
Default k member help
i was wondering if its ok to remove this bolt. i need to remove the k member to get to a few bolts and slide the engine forward. the bolt is really hard to push through the hole and i was wondering if there is any weight or anything resting on this. i do have the wheels on jacks to make sure but i want to double check with you guys
[IMG]local://upfiles/49575/3AB81985FD51456EA52C064FC5B7A56B.jpg[/IMG]
[IMG]local://upfiles/49575/9A31ADB7D94C4D6DB0506A26588F6DB0.jpg[/IMG]
five0fm is offline
Old 04-02-2007, 12:08 AM
ckyguy68
ckyguy68's Avatar
Default RE: k member help
What bolt are you refering to? The bolt in the bottom pic is a control arm bolt. Taking that off would cause a few problems.
ckyguy68 is offline
Old 04-02-2007, 12:11 AM
five0fm
five0fm's Avatar
well the k member or what ever its called is connected to it. and yes im referring to that bolt what are the problems going to be
five0fm is offline
Old 04-02-2007, 12:21 AM
five0fm
five0fm's Avatar
anyone know what problems i will have? anything i can do to prevent them?
five0fm is offline
Old 04-02-2007, 12:41 AM
five0fm
five0fm's Avatar
does anyone have any idea. im in the middle of trying to take this out and i really need advice
five0fm is offline
Old 04-02-2007, 12:48 AM
50Trippin
50Trippin's Avatar
If you are removing the k-member you need to support the car differently. when you remove the k-member the control arms, rack & pinion, motor mounts all come with it. you need to support the car by the frame and also support the engine with a hoist.
If you take the control arm bolt out now the way you have it supported, if you even could get it out, the car would not be supported anymore and would fall to the floor damaging everything in the way of the control arms.....
50Trippin is offline
Old 04-02-2007, 12:51 AM
5.0stanger
5.0stanger's Avatar
That bolt looks to be the rack bolt, not the control arm bolt. You shouldn't have to remove it.
5.0stanger is offline
Coyote_hpr
11-12-2019 12:44 PM
rgingo
Forum Issues and Feedback
10-21-2015 12:49 PM
Dokilar
15
10-16-2015 08:13 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Quick Reply: k member help
