Oil Pan Gasket
Oil Pan Gasket
k...i got this new oil pan gasket...no instructions 'casue it should be straight forward..but...do i need to use gasket glue to attach it or can i just install and bolt the pan on. i remember when i did my old honda, the manual recomended a bit of grease to hold it in place and seal until it was tightened up.
RE: Oil Pan Gasket
No grease required. Stupid Hondas.
Is it a 1 piece? You will want to put a semi-healthy gob of black RTV at each corner of the front and rear main seals (like the corner where timing cover meets the oil pan)
